AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Spec sync problem cat->spec->model->report
1 REPLY 1
snijdam
439 Views, 1 Reply
I try to exlain what my problem is as clear as possible.
I made a spec in a normal way. I use this spec in my piping file. No problems so far.
Next I modify the description of some parts in the catalog. I updated my spec an the parts in the model. Still no problems.
When I make a 3D parts report with the report creator I see the old description. Problem!
When i look in the datamanger in my piping file I see only the correct decriptions. Also when I export my datamanager file and import it back in.
When I check the properties of some parts in the piping file I see the new description.
How is this possible?
1 REPLY 1
Dan.Scales
in reply to: snijdam
Try clearing out the local data cache by running the PnPLocalDataCachePurger.exe from the install folder of the product.
Dan
Dan Scales
”Boost
