AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Spec Sheet Print Out
2 REPLIES 2
jtegtmeyer
563 Views, 2 Replies
Is there a way to add a column for tags or material code to the spec sheet printout?
AutoPlant 3D 2014
Thanks, Teg
Tags (1)
2 REPLIES 2
Hi Teg,
From the Spec Editor you could "Export to Excel" and add a column there in Excel. Print from there.
(If this answers your question, please mark it as an Accepted Solution.)
Martin Stewart
AEC Support Specialist
Martin, I would like to add this within the spec editor so I don't have to take that extra step, export, add columns and move around text. There are a couple of columns I would like to add inside of the spec editior.
”Boost
