AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Spec sheet grouping
2 REPLIES 2
tmccar
392 Views, 2 Replies
Spec sheet grouping
When I add flanges to my pipe spec, they appear undefr "Couplings" in the spec sheet and there is no "Flange" section on the sheet. How can I ensure there is a Flange section in the spec?
Tags (1)
2 REPLIES 2
Rich.O.3d
in reply to: tmccar
are these flanges that you have created or ones from the supplied catalogs
If you created them, did you make sure you had Flanges selected from the component category drop down box?
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
tmccar
in reply to: Rich.O.3d
You're right - I remade them under "Flange" category and they now appear under Flanges when I add them to the spec. They had been created under "couplings"
”Boost
