AutoCAD Plant 3D General DIscussion
Valued Mentor
tmccar
Message 1 of 3 (213 Views)
Spec sheet grouping
213 Views, 2 Replies
11-29-2012 06:45 AM
When I add flanges to my pipe spec, they appear undefr "Couplings" in the spec sheet and there is no "Flange" section on the sheet. How can I ensure there is a Flange section in the spec?
are these flanges that you have created or ones from the supplied catalogs
If you created them, did you make sure you had Flanges selected from the component category drop down box?
Valued Mentor
Rich.O.3d
Message 2 of 3 (198 Views)
Re: Spec sheet grouping
11-30-2012 05:57 AM in reply to: tmccar
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Valued Mentor
tmccar
Message 3 of 3 (188 Views)
12-01-2012 03:30 AM in reply to: Rich.O.3d
You're right - I remade them under "Flange" category and they now appear under Flanges when I add them to the spec. They had been created under "couplings"
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
