When I add flanges to my pipe spec, they appear undefr "Couplings" in the spec sheet and there is no "Flange" section on the sheet. How can I ensure there is a Flange section in the spec?
Solved by Rich.O.3d. Go to Solution.
are these flanges that you have created or ones from the supplied catalogs
If you created them, did you make sure you had Flanges selected from the component category drop down box?
You're right - I remade them under "Flange" category and they now appear under Flanges when I add them to the spec. They had been created under "couplings"
