AutoCAD Plant 3D General DIscussion
Valued Mentor
9 Kudos
Post 1 of 7
Spec Palette refresh speed
338 Views, 6 Replies
01-11-2013 06:22 AM
I change pipe specs in my project many times a day and I find that it takes a long time for the spec palette to refresh. Is there anything I can do to speed this process up?
I recommend disabling the spec tool palette using PLANTDYNAMICTOOLPALETTE, and running using the spec viewer instead.
The tool palette is being built from the spec. Most likely the spec is on the network server. If there is a slow network connection, then it can take a bit longer. Have seen on many occasions that the anti virus software is scanning as it is reading the spec from the server.
Specs on a local machine should only take a second or so to build the tool palette, as long as there is no anti virus scanning.
Valued Mentor
9 Kudos
Post 2 of 7
Re: Spec Palette refresh speed
02-02-2013 08:09 AM in reply to: tmccar
Anyone from Autodesk reading this? Even if you could say, "we are aware of this but don't have a fix for it as yet", that would be helpful. Surely this has been brought up before?
Active Contributor
9 Kudos
Post 3 of 7
02-04-2013 05:25 AM in reply to: tmccar
How long is it taking to refresh? There is a bit of delay while it loads the palette, but when I change specs it only takes about a second after changing the spec in the pull down to the palette loading.
Valued Mentor
9 Kudos
Post 4 of 7
02-04-2013 10:03 AM in reply to: rchiasson
About 30 seconds. It may not seem a lot but when you are changing frequently, it can be frustrating.
143 Kudos
Post 5 of 7
02-05-2013 02:12 PM in reply to: tmccar
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
Active Contributor
9 Kudos
Post 6 of 7
02-05-2013 02:24 PM in reply to: dave.wolfe
Agreed
Employee
7 Kudos
Post 7 of 7
02-06-2013 03:36 PM in reply to: rchiasson
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
