AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Spec Layout and Settings, Modify Catalog Properties
1 REPLY 1
Icegambit
422 Views, 1 Reply
So i have finally gotten the Modify Catalog Properties to work after finding out that I have to create a property in the catalog and then also in the spec sheet itself for the information to be transfered over. Now i would like to have the property imported into the long description for ISO creation. I know i can create the description by editing the specs Layout and Settings, but am currently not able to put my custom field in as one of the properties it allows. How do i get it so that my Custom property can be put into the Iso Description?
1 REPLY 1
KenFauver
in reply to: Icegambit
Have you tried exiting Spec Editor and reopening the Spec Editor? It may need to reload the XML file that got updated with the new property.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
”Boost
