AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
spec editor and branch table
5 REPLIES 5
GSC_HAYA
894 Views, 5 Replies
Hello
when I insert a reduced tee with reducer in the legend, click OK and reopen the legend, so the reducer has been removed by the reduced tee. Always!
What is wrong?
Guido
Plant3D 2022 German
WIN10 Pro
5 REPLIES 5
Hi Guido,
this is because the tee is already reduced. So you have not to add a reducer here. This is already done by the part itself. Do a cross-check here. If you add a normal tee (not a reduced one) to the legend where you check the column 'add reducer', this will be saved. After a re-open of the legend you can still see the check here.
Bernd
Bernd G.
Senior Product Support Specialist
JohnHolder
in reply to: GSC_HAYA
are you trying to reducer further down than the reducer tee?
eg?
12" tee reducing to 10" and your going to 8"
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
GSC_HAYA
in reply to: JohnHolder
Hi
thanks for the answers.
Yes it is ok when I use a not reduced tee.
And yes I want to reduce further down.
In EN 10253 you have for example a tee 500/250, but you need a branch 200, so I must reduce with a reducer.
(I can not use a olet or stub in because it is not allowed)
Guido
Plant3D 2022 German
WIN10 Pro
JohnHolder
What is most likely happening, it is getting confused with the reduction tee to a reducer.
You may for now untill a more knowledgeble person jumps in, manually add the reducer after putting in your reduction tee.
Master Yoda.
Venkatesan.A
FYI.
This option (defining a reducer/reducing fitting on top of reducing fitting) is currently not supported in S &C  branch editor.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
”Boost
