Hello
when I insert a reduced tee with reducer in the legend, click OK and reopen the legend, so the reducer has been removed by the reduced tee. Always!
What is wrong?
Guido
Solved by Venkatesan.A. Go to Solution.
Hi Guido,
this is because the tee is already reduced. So you have not to add a reducer here. This is already done by the part itself. Do a cross-check here. If you add a normal tee (not a reduced one) to the legend where you check the column 'add reducer', this will be saved. After a re-open of the legend you can still see the check here.
Bernd
are you trying to reducer further down than the reducer tee?
eg?
12" tee reducing to 10" and your going to 8"
Hi
thanks for the answers.
Yes it is ok when I use a not reduced tee.
And yes I want to reduce further down.
In EN 10253 you have for example a tee 500/250, but you need a branch 200, so I must reduce with a reducer.
(I can not use a olet or stub in because it is not allowed)
Guido
What is most likely happening, it is getting confused with the reduction tee to a reducer.
You may for now untill a more knowledgeble person jumps in, manually add the reducer after putting in your reduction tee.
FYI.
This option (defining a reducer/reducing fitting on top of reducing fitting) is currently not supported in S &C branch editor.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
