AutoCAD Plant 3D Forum
Spec Editor - Advanced Editing Table - minor issue
4 REPLIES 4
JohnHolder
336 Views, 4 Replies
While recreating my sch 40 and PVCu specs and rebuilding catalogs ( hopefully properly this time ) I found a problem.
I am creating a component - flush bushing - it has 2 ports of different sizes ( this issue only comes up with different port sizes )
the S1 port works great
type in a number
enter
type in a number
enter
etc etc.
S2 port does NOT work this way.
click
click
type in a number
enter
click
type in a number
etc
S1 I can click a cell and type
S2 I have to double click a cell to type.
for 52 fittings, this is not enjoyable.
and when I start doing reduction tee's that has 3 orts....
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
4 REPLIES 4
jason.drew
in reply to: JohnHolder
It looks like the tab order needs to be changed on the form. You should be able to type in a value and then press the TAB key (or Enter key) to move down to the next field. I will submit this to the development team.
Thank you,
Jason Drew
Designated Support Specialist
JohnHolder
in reply to: jason.drew
I just reopened it and tried hitting tab,  it moves it horizontally not vertically.
enter does bring it down a level, but does not let you type in a new number, I have to click first.
Master Yoda.
jason.drew
Have you tried the new Catalog Builder that comes with Plant 3D 2013? It's a much easier way to create catalogs:
Plant 3D 2013 Catalog Builder
Jason Drew
JohnHolder
Yeah working with excel is much easier, but the catalog builder seems to think "No Excel installation was found"
while I use excel on a daily basis.
I attempted to put a few fittings into it then export it to excel.
when I attempt to open it, excel has to repair it.
when I attempt to create a catalog i get the error "No Excel installation was found"
then I get a hanging window "validateing" that does not want to go away.
Master Yoda.
”Boost
