While working in Specs and Catalog Editor, it crashes without warning. Is there a remedy for this? I have lost a lot of work already.
Default Plant 3D installer should install Spec & Catalog editor. Can you go to the following location and look for this file.
C:\Program files\Autodesk\AutoCAD 2014\PLNT3D\SpecsAndCatalogsEditor.exe
Try running the above exe and see whether it installs. If you don't see this exe file, do let me know.
I don't see it in the location above. I have located it in:
"C:\Program Files\Autodesk\AutoCAD Plant 3D 2013 - English\SpecsAndCatalogsEditor.exe"
