AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Spec Editor 2013 Crashes
3 REPLIES 3
cad.westie
712 Views, 3 Replies
Spec editor crashes whenever I make any changes to a catalog, I get the following error :
Problem signature:
  Problem Event Name:                        CLR20r3
  Problem Signature 01:                       specsandcatalogseditor.exe
  Problem Signature 02:                       4.0.203.0
  Problem Signature 03:                       51e4dd4e
  Problem Signature 04:                       PnP3dCustomControlLibrary
  Problem Signature 05:                       4.0.203.0
  Problem Signature 06:                       51e4dd14
  Problem Signature 07:                       2fb
  Problem Signature 08:                       d
  Problem Signature 09:                       System.NullReferenceException
  OS Version:                                          6.1.7601.2.1.0.256.48
  Locale ID:                                             5129
  Additional Information 1:                  28ef
  Additional Information 2:                  28ef4fd99739593c8a9fb737536843c6
  Additional Information 3:                  54d9
  Additional Information 4:                  54d98f134889b9c8f18709bbe00afde5
I have tried uninstalling plant3d completely (deleting folders) and then reinstalling with no success, I am running windows 7 64bit.
3 REPLIES 3
Have you tried doing a clean uninstall as per the below procedure,
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=14116967
Also you may want to remove all the .NET applications and allow the Plant 3D installer to run the one that's needed for yours. Its version 4.0. Later you could install other versions based on your other software requirements.
Do let me know, if the problem persists after .NET reinstall.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
cad.westie
in reply to: cad.westie
That seems to have fixed the problem, it must have been .net 4.5. Thanks for the quick response.
[Description: cid:image001.png@01CD7FB2.6DD3DD80]
Peter Harrison
Design Engineer
SPX Flow Technology New Zealand
5 Eden Street Newmarket
Auckland
New Zealand
TEL +64 9 523 7360
MOB +64 21 572 175
FAX +64 9 523 7378
peter.harrison@spx.com
www.spx.com
The information contained in this electronic mail transmission is intended by SPX Corporation for the use of the named individual or entity to which it is directed and may contain information that is confidential or privileged. If you have received this electronic mail transmission in error, please delete it from your system without copying or forwarding it, and notify the sender of the error by reply email so that the sender's address records can be corrected.
viet_protocad
I've been getting this message in both 2014 and 2016. I don't think its specific to my install of Plant3D since it would be weird to have it affect both 2014 and 2016. This suggests to me that its more of an issue where windows is bonking out as opposed to Plant.
I've uninstalled and reinstalled .NET multiple times and it still crashes every time I try to make a new component.
Have there been any whitepages about how to fix this issue?
”Boost
