I am running Plant 3D 2015 and am a fairly new user to this flavor of autocad. I am working ona project that requires me to edit the standard C150 spec. I understand how to get into that spec and insert new components, but when I save that and go back into Plant 3D that spec has not changed. It is still the default list. The knowledge base said there should be a Spec Syncroization button in the catalog tab, but I do not have an option for that in my spec editor. Does anyone have any suggestions?
Solved by jabowabo. Go to Solution.
You need to edit the spec in the current project folder structure (Project/Spec Sheets). Or, you can edit outside of the project and copy the spec into 'Spec Sheets'.
