AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Spec Descriptions - Shortcuts
3 REPLIES 3
JoeKay
237 Views, 3 Replies
While filling out spec descriptions in the Spec Editor, is there a way to enter short cuts so that some info is automatically filled, like sizes? For example: You have a Fitting and in the Long Description Size column you enter "Tee, X" Schedule 80". Is there a way were I can automatically substitute the 'X' for the actually size of the part. It would cut down on the time to enter descriptions if I can have all the sizes filled automatically instead of entering all the sizes for each part. Thanks.
3 REPLIES 3
jabowabo
in reply to: JoeKay
Have you looked at Long Description Styles for specs?  I think that's the only supported way you can do close to what you describe.
JoeKay
in reply to: jabowabo
that may work. I'll look into it. Thanks.
Gabriel.N
in reply to: JoeKay
Hi Joe,
I'm not sure, I filled manually.
Att.
Gabriel Nogueira.
”Boost
