Hi Alex
Yes, we can do that. The Spec Update function can be used if you have done any changes in Spec A, after you have routed your pipe with Spec A. In this case, it will update the existing component from Spec A, with new value from your updated Spec A.
If you want to change from Spec A to Spec B on a existing pipe, you need to do follow.
• Right click on your pipe and select “Append to Selection” by “connected Part” or “Line Number”
• Select then properties and change your spec in the properties box.
It will change your spec, but if you have any fit to fit, you need to adjust this after spec name change.
Dag Austrheim
