All,
This is related to AutoCad Plant 3D 2015. In order for a spec blind with gasket to attach to a flange, I have used the custom builder to define the properties. This worked, but I have to redefine it every time I open AutoCad Plant 3D 2015. Is there a way to set the properties permently unless redefined?
Thank you,
Celeste
Hi Celeste,
Is this issue closed? I was watching to see what the answer would be but it looks like no one has worked with you on this issue.
Bryan
