I want to modify the specs and catalog to be project specific. If I copy and paste .pspc and pspx and pcat to another drive other than C: what other files/folders do I have to copy?
Solved by dave.wolfe. Go to Solution.
We have a blog article on the topic here.
http://www.pdoteam.com/2012/02/setting-up-network-catalogs-for-autocad-plant-3d/
I strongly recommend that your catalogs are not project specific, unless you really have to. The catalogs are designed to be a part repository that you can use to add components to as you need them. That way, over time you build a complete set of the content you need in your projects. Specs can be project specific, or shared among a group of projects. By default, Plant 3D stores specs in a project folder when you create a new project.
Please mark my post as the answer if it answers your question. Marking answers helps other find solutions faster. Thanks!
Yes, a pcat on the C:\ is only accessible by one person. The article at the link I posted shows how to put it on a network for people to access on the network.
