I am reviewing Plant 3D 2014, I have migrated my catalog and specs across. When I open them in the spec editor the image or sizes do not appear. This happens with the regular ASME catalogs as well. I have attached a screen shot to show what I mean.
Solved by PatrickByrne. Go to Solution.
Found the problem, I had copied the catalog files to a common location but this was not working out. I then specified the old location but had not copied across the file ContentConfig.xml. Everything is okay now.
