AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Sloping pipework
1 REPLY 1
341 Views, 1 Reply
Sloping pipework
How does Plant 3D handle sloping pipework. Angles can vary from a few
degrees to 90 degrees.
1 REPLY 1
gulnacm
You can slope pipe 2 ways prior to routing you can activate the slope panel on the 3D Piping Home Ribbon this will slope horizontal pipe per the specified ratio.
The second can also slope pipe after it has been already routed by using the command PLANTPIPESLOPE. This will allow you to slope a selected route with multiple segments and enter a common slope. Choose the starting pipe segment then the last pipe segment even if its across multiple piping fittings and other pipe segments.
Mike G (Autodesk)
Michael Gulnac
Technical Specialist
Organization
Autodesk, Inc.
”Boost
