To whom to concern
I have Done it the Flange DIN PN16 From Size 20 to 900 and I added in the catalog
Please refer the attached file. the Name In the Catalog Is (FLANGE DIN2543, PN16 (EN 1092)
After I mad All Flanges Size I didn't Realize The defferent Color for Each Size, how can i change the color to matched.
For More Clarification please refer the Screen Shot
Ahmed Helal
Solved by Dan.Scales. Go to Solution.
Hi Ahmed,
The 3D solid needs the color to be set to "ByBlock" if you want it to inherit the color of the pipe that it is placed on.
Dan
Thanks Dan For Your Reply,
You mean I have To Make Again all one by one and adding in the Catalog, i was think there some another way instead to replace all one by one
Ahmed Helal
Hi Ahmed,
You should be able to edit the blocks in the DWG folder of the catalog.
The change will only be seen in new drawings though. Existing drawings will need to have any flanges deleted and purged from the drawing.
Dan
Hi Dan,
I have duet to understand you information can please be more specific
Ahmed Helal
Hi Ahmed,
In the DIN folder there is a subfolder called DWG:
C:\AutoCAD Plant 3D 2013 Content\CPak DIN\DIN Valves Catalog\DWG
This is where the drawings containing the blocks of the custom flanges are stored. You can open the drawing and using BEDIT modify the flanges color to ByBlock.
Dan
