how to add sight glass, reinforcement pad in spec editor?
reinforncement pad is available but where will i get the dimensions?
I found reinforcing pads in 2014 version faulty in ISO extraction , so what i did is create a custom Reinforcing Pad using an OLET category and it works like a charm. Thanks
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
If you are familiar with custom modelling of components then that should work. Model your sight glass in autocad, convert it to block. use the command "plantpartconvert" then assign ports (like port 1, port and so on) in your model block. Save your DWG then create a new component in the Catalog editor using your block, thats it. I'll attach pictures later if you need it. thanks
Best Regards,
Pat Andres
GHD Manila
