Hello
Is there any way to force iso generator to show a special field of an object ( for example nominal size of each elbow ) in generated iso ?
I'm waiting !
on the iso itself, so you want the part number, then the field?
Thanks for reply.
In fact I’m going to add a field to fasteners (butt weld, slip-on, thread, socket weld,...) called "joint number" instead of weld number because it is not possible to specify weld number for slip-on flange in 3D model and there is not this for threaded joint and the joint number should be shown instead of weld number in iso including annotations .sometimes there are 2 joints for an item for example R.F.PAD Of course there are some extra fields that are relative to joint number : pipe fitter code, date of fit-up, welder code, weld date, fit-up contractor, weld contractor,... and finally I hope show all of these in Excel ,so I change the values using excellent excel command and their value will change in P3D.
