I don't guess there is a command that i don't know of that works like AutoPlants Align Fittinigs command? it made routing a lot eaiser, or is this just one to add to the wish list?
Solved by quentin.contreras. Go to Solution.
Never hurts to ask, but unfortunatly there is not a similar command available in Plant 3D. I will however, send this off to development as a wish list item.
If you would like to express to our developers why this feature is important to you, you can use the following feedback link:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Quentin Contreras
Technical Support Specialist
