I ran my first test Isometric on Plant3D. The Iso included a flanged gate valve which was shown on the shop material BOM not the field material BOM. To force the valve into the field material BOM, I added the shop-field property to the asme valve catalog and propagated this setting to the spec. Now when I run the same Iso the valve does not appear in the shop or field BOM. I noticed that now when I check the properties of the valve in the model, the shop/field property is not available but, when I check the valve in Datamanager the property is set to field. How can I get the valve to show up in the field material BOM on the Isometric?
Solved by jabowabo. Go to Solution.
Make sure that the SHOP/FIELD text in your catalog and spec is all upper case.
How do you ADD this field to the catalog v2018? I would love this option to force valves and other items into the field erection section of the BOM
