AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Several problems about the ISO generation..
2 REPLIES 2
winner117
751 Views, 2 Replies
I have a few question about the setting result of the generated iso. 1. The annotation is far from the line or in the strange location (see attach 1) 2. There is too many elevation on the same iso drawing….. 3. How to get rid of the dimension of the blind flange? 4. How to show the support tag on the iso? 5. Every time I insert a SKEY=SUPP guide, part of the drawing will be compress to a strange style….., and also the guide direction is wrong…. (see attach 2) 6. Where is the PH IMPERIAL come from? I can’t found it in my spec…..(see attach 3) I know it's a lot of question...... But I really need someone can help me on this.... =.=
2 REPLIES 2
richard.imrie
in reply to: winner117
Was there ever a solution to this post?
i am having similar problems with dimension of blind flange and dimension text location.
You will not get reply from Autodesk, as this is an issue.
”Boost
