AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Setting up a Fiberglass Spec.
6 REPLIES 6
universalpiping
821 Views, 6 Replies
I am having trouble setting up a basic fiberglass spec, using the bondstrand catalog that I downloaded from here.
Are there are sample specs available? or does anyone have a spec that they are willing to give to me? Im working on an industrial waste line.
Intel(r) Xeon(R) CUPI E3-1505Mv5@2.80ghz
32 gb ram
win 10 x 64 bit OS x64 based processor
Autocad Plant Design Suite Ultimate 2017
6 REPLIES 6
Gabriel.N
in reply to: universalpiping
Any help, please....
Venkatesan.A
in reply to: Gabriel.N
Could you please give us more information on the issue you are having?
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
The spec is something that the process engineer or customer will tell you.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Tom,
He had mentioned that he has some issues setting up Fiberglass spec, I recently helped a customer to set up Fiberglass spec (Bondstrand) so I am trying to get an idea on what type of issue he is having.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
I understand, but setting up a spec needs some more information than just the catalog. For example, whats the size range? Are there any extra rated fittings etc in it? Also the branch table needs to be defined, but its not like there is a 'standard' piping spec, they vary from project to project, and from client to client.
I'm not sure on what the OP is asking, is the catalog the issue, or making the spec?
Tomislav Golubovic
Autodesk, Inc.
Thats exactly what I am trying to understand from him.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
”Boost
