AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
service pack 1 for version 2015
1 REPLY 1
Peter_Jansoone
375 Views, 1 Reply
the readme states :
If you select piping in the 3D model, you can now specify both component properties and connector properties in the properties palette. This makes it easier to specify ISO split points if you split when a property changes.
But I'm not finding any change in properties palette ?
Peter Jansoone
Plant Design software consultant at Arkance Systems Belgium
1 REPLY 1
dave.wolfe
in reply to: Peter_Jansoone
There isn't a visible change, but when both are selected you can make changes to both at the same time. Previously the connector wouldn't accept the changes
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
”Boost
