AutoCAD Plant 3D General DIscussion
Active Contributor
btrevena
Message 1 of 2 (405 Views)
Segment Breaker - P&ID
405 Views, 1 Replies
07-10-2011 10:45 PM
The default P&ID Segment Breaker (in PIP) has Spec identifier annotations either side of the break.
However, when the break is applied to a P&ID process line it does not change the line spec on the downstream side of the break to "?".
It does however reset Service and Size fields for the downstream side of the break to "?" on the Line Tag annotation.
Can a control be added to the Segment Break symbol that enables the setting of the annotations presented and the associated data fields to be reset to "?".
BruceT
Employee
raj.inugala
Message 2 of 2 (374 Views)
Re: Segment Breaker - P&ID
07-12-2011 10:13 AM in reply to: btrevena
Hello btevena,
I am trying to reproduce what you described in your post. Are you placing the Spec Break from the tool-palette directly onto the SLINE? Or are you using the SLINE's context menu to add a break?
Raj.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
