AutoCAD Plant 3D Forum
Section Volume, what is the point?
1 REPLY 1
kaiser6977
306 Views, 1 Reply
I can create a section volume in a 3d view, but what is the point. All it does is put a pretty little box in the view that you can resize and move around. It does not cut out any objects to aid in viewing the area you are working on.
If I am missing something and the Section Volume does work as it should and I am missing it, please help!!!
1 REPLY 1
ausdag
in reply to: kaiser6977
Hi Kaiser
It does, but can you give me a example on how it should look like?
This can be done in several way, since you also can use the basic AutoCAD command for your views.
Can you please attach a typical example? That will help me a lot to see exact what you looking for.
Dag Austrheim
”Boost
