AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
saving drawing "An item with the same key has already been added"
7 REPLIES 7
Message 1 of 8
Hermann.Semlitsch
1406 Views, 7 Replies
hi,
i have a intressting message when i save my model.
can anyone explain me this.
7 REPLIES 7
Message 2 of 8
-Hi,
Are you using Autodesk Vault menu inside AutoCAD, to save your files?:
http://forums.autodesk.com/t5/Autodesk-Vault/Error-quot-An-Item-with-the-same-key-has-already-been-a...
If not, it could be linked to Windows 7:
http://support.microsoft.com/kb/2383895#appliesto
Best regards
Autodesk logo
Laurent Pallarès
Product Support Specialist
Autodesk, Inc.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Message 3 of 8
thanks for the answer but we don´t use Vault and the Windows help doen´t help.
i think i added a part to the 3d model from the Pipe Spec which i have before creted as an custom part. and i used the same "plantpartconvert - Object" for both, custom part and than Pipe Spec Object. Can that be the problem?
Message 4 of 8
Is there an answer yet for this problem? Because now I'm having the same problem, when trying to create an iso.
The error is on a stub-in weld, if everything, except the stub-in weld is selected, a good iso is being drawn, but when I select the stub-in weld (with or without the 2 connecting pipes) I get an iso Error.
Deleting and replacing the weld had no success, also changing the weld from Shop to Field or Field-Fit.
Who can help me, solving this problem.
Message 5 of 8
i can´t remember what i have done. this is 5 years ago. sorry but i think, i found no solution. i had this Problem no more in future. maybe because of complete new Project configurations.
Message 6 of 8
Jan-TSpD
in reply to: M.deKort
Hi, i am facing the problem. Did you already find or get the solution?
regards, Jan
Message 7 of 8
dave.wolfe
in reply to: Jan-TSpD
Usually this would show up if you have duplicate attribute tags in your Iso title block. Make sure all of your attribute tags are named something unique. Use the autocad BATTMAN command to pick your block and show the attributes. AutoCAD highlights duplicate attribute tags in red.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 8 of 8
Jan-TSpD
in reply to: dave.wolfe
i am using the title block for different pipelines, some of them are okay and some of them come with the error.
regards, Jan
”Boost
