hi,
i have a intressting message when i save my model.
can anyone explain me this.
An item with the same key has already been added
-Hi,
Are you using Autodesk Vault menu inside AutoCAD, to save your files?:
If not, it could be linked to Windows 7:
http://support.microsoft.com/kb/2383895#appliesto
Best regards
thanks for the answer but we don´t use Vault and the Windows help doen´t help.
i think i added a part to the 3d model from the Pipe Spec which i have before creted as an custom part. and i used the same "plantpartconvert - Object" for both, custom part and than Pipe Spec Object. Can that be the problem?
Is there an answer yet for this problem? Because now I'm having the same problem, when trying to create an iso.
The error is on a stub-in weld, if everything, except the stub-in weld is selected, a good iso is being drawn, but when I select the stub-in weld (with or without the 2 connecting pipes) I get an iso Error.
Deleting and replacing the weld had no success, also changing the weld from Shop to Field or Field-Fit.
Who can help me, solving this problem.
i can´t remember what i have done. this is 5 years ago. sorry but i think, i found no solution. i had this Problem no more in future. maybe because of complete new Project configurations.
Usually this would show up if you have duplicate attribute tags in your Iso title block. Make sure all of your attribute tags are named something unique. Use the autocad BATTMAN command to pick your block and show the attributes. AutoCAD highlights duplicate attribute tags in red.
i am using the title block for different pipelines, some of them are okay and some of them come with the error.
regards, Jan
