How do you create custom clamp?
In spec editor when I change graphics to custom dwg block, I can no longer chose clamp as component category.
How to work around this? Using 2015 version.
Hello Mr. btrevena,
this is rather genious
Thanks for clear instructions, however I got lost at the end. Which file did you mean by Plant 3D modelling template (dwt file) ? I am not exactly sure which one you meant.
To be clear, clamps with true geometry don't even need to be part of cat/spec?
Hi jer.luka!
It is simple, but you have to do a workaround.
You need to edit in the 3D model the default Plant 3D clamp block.
1. Make a collection 3D model where you store all 3D solids of your clamps.
Something like this:
Set the properties of these solids to:
color: by block; layer:0; that the rest are by layer
I used lines to ealisy grab the models in the zero point later.
2. Enter BEDIT command in your piping 3D model and look for something like
Plant3DCatalogitem_CCLAMP......
and simply just copy-paste your tri-clamp solid into the block zero point and delete the default block.
You can use that line to esaily locate the zeropoint of your tri-clamp solid.
Than close the block editor, save.
If you have multiple sizes you have to repeat the procedure for all sizes.
Also this works only in that 3D piping model.
But that is it!
Good day I´d like to know if you can help me, I download the Pharma Content Pack V2 but the tool library does not appear at the tool palettes nor even in the spec sheet so how can I configured it ?
I download >>Component package Pharma but when I want to added at the catalogue in Spec Editor the files that I have are .PCAT
and the ones that recognize are .pspx what can I do ? or how do I change them
I still have doubts, I send you screenshot of how does the spec editor appears to me, I consider that probably there is someting wrong with the Autocad plant 3d content that I download.
Thanks for the attention.
I have the package IPS Pipes & Fittings Cataloge - Imperial Metric and at the video they show the use of a TRICLAMP, I have that clamp at my spec editor but it does not appear at the tool palate so I can not draw it
A clamp is a fastener, so it wouldn't appear on the pallete as gaskets and bolt wouldn't.
Make sure the clamp is defined in the catalog using the 3D block and added to the spec and it should appear when you make a clamped connection.
Hi Shaun,
In the DIN11864 content I have added the "TriClamp" like 3025 Single Pin clamp 3D Block geometries to the Coupling section.
When you place 2 x DIN11864-3 ferrules face to face in your piping model the clamp that is placed is 3019 bolted clamp that uses the default clamp parametric body. (It is still not possible to add 3D block geometries for clamps to the catalogues.)
To achieve having 3D Pinned Clamp geometries appear when ferrules are added to your model you need to replace the default clamp objects with geometries from the pinned clamps. This only needs to be done once as follows:
- Open your <3D Modelling>.dwt template drawing.
- For each tube size add ferrules face to face so the the 3019 default clamps appear.
- Adjacent to each 3019 clamp place the equivalently sized 3025 pinned clamp. They have been added to the catalogue as coupling components and can be placed from the palette.
- Explode all the clamps to block components.
- For each size do the following:
1- Block Edit the 3025 pinned clamp, Select All, Copy to Clipboard with Base Point 0,0,0
2- Block Edit the 3019 bolted clamp, Delete All, Paste the Clipboard to 0,0,0
3- Save the block
4- Repeat for each size
- Save the dwt file.
- New models created from this dwt file will have your custom pinned clamp block geometries present when ferrules are connected.
regards,
Bruce
Dear Mr. Vallyon
Can you create a video explaining this process on youtube for example? .. It would be a great help for me who failed to understand these settings .... Thank you !!!
