AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
S.S. w/tri-clamp specs?
1 REPLY 1
1252 Views, 1 Reply
We are considering buying Autocad Plant Design Suite. One thing that I am specifically looking for is pipe specifications in the 3D software that we use all the time.
Most of the pipe/plant design that we do here are at Pharma plants so we need specs that include the following:
Copper fittings
BPE fittings
Stainless Steel Tri-clamp fittings
SS compression fittings
Hoses
Do these specs exist or can they be made?  If they don't not sure we will buy the suite. We use these specs all the time
1 REPLY 1
rajsekarpillai
Hi Phil Shanks,
Thanks for your request!
We have already identified the ASME BPE standard is impatient Catalog for Plant 3D. I can't assure the date, but certainly we are looking at BPE.
You can also build these catalogs through AutoCAD Plant3D Catalog Builder.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
”Boost
