AutoCAD Plant 3D General DIscussion
New Member
rommel.agno
Message 1 of 3 (443 Views)
Run Plant 3D Specs without Administration rights
443 Views, 2 Replies
09-12-2012 08:25 PM
Any one know a way to allow user to run the “Plant 3D Specs and Catalogs Editor” without Administrator Rights on the local Computer? i'm using Plant 3D 2013
*Expert Elite*
dave.wolfe
Message 2 of 3 (413 Views)
Re: Run Plant 3D Specs without Administration rights
09-13-2012 04:10 AM in reply to: rommel.agno
I think you would have to turn UAC off for Windows 7.  The program saves some files to the program files folder which is a protected location in Windows.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
juha.hanninen
Message 3 of 3 (267 Views)
01-22-2013 06:03 AM in reply to: rommel.agno
the problem is that the certificate of the Spec editor is not valid.
It is stamped
Valid from 27.8.2009 to 21.9.2012
See the screen capture attachment.
I think Autodesk should correct this ASAP.
Announcements
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
