Any one know a way to allow user to run the “Plant 3D Specs and Catalogs Editor” without Administrator Rights on the local Computer? i'm using Plant 3D 2013
I think you would have to turn UAC off for Windows 7. The program saves some files to the program files folder which is a protected location in Windows.
the problem is that the certificate of the Spec editor is not valid.
It is stamped
Valid from 27.8.2009 to 21.9.2012
See the screen capture attachment.
I think Autodesk should correct this ASAP.
