is it possible to create a valve which will let you rotate the port direction in the model?
so 1 valve will have the option to either run straight through with the ports at 180 degrees to each other, or the other option as a right angle?
Well,
not that I know of.
But why don't you set up a single 3-way valve instead?
You can set up ISO symbol for that too, if you do that way.
hi,
i have attached a screenshot of what i am wanting to do.
I dont want to have to create a seperate model for each configeration as we have a lot of different types of valves similar to this. it would be a lot easier if we could rotate 1 of the ports after inserting it into the model.
