AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
rotate ortho cube
5 REPLIES 5
patpat78
703 Views, 5 Replies
rotate ortho cube
hello i have a big probleme
i have  a project with different unit and different angle
my problem was: whane i m in an area with aprox 8° of rotation whan i generat the ortho view i can't have the real face extracted
is it possible to rotate that cube???
i think it's a very big problem a lot of my project are not perpendicular .....
any idea ?
5 REPLIES 5
The ortho generation is purely a N-S-E-W cube.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
patpat78
in reply to: patpat78
i thonk this is a very big problem on plant3d ... 90% of my projet are oriented..
i'm testing plant3d for my company and with that ......
please fix that on 2013 rlz
thank's
AndyDavisCadline
A possible workaround for you could be to create a new drawing file from which to generate the ortho views.  Xref your model into that new file as an attachment and rotate it by the required angle.
Andy
Andy Davis
Industry Specialist
Cadline Ltd.
patpat78
yes i know that it's what i do
but it's not realy fun to have to do this.. i spend a lot of time with this problem..
but thank's
Vitornis
I also am having an issue with this.
”Boost
