AutoCAD Plant 3D Forum
Retain Isometric Annotations
1 REPLY 1
362 Views, 1 Reply
If I create an isometric drawing and add an annotation to the face of it, it gets removed if I have to run the iso again. There are lots of circumstances that annotations need to be retained is this possible in Plant 3D? I know it can be done in other programs that use isogen.
1 REPLY 1
gulnacm
currently our isogen generation does not retain any information from previouse iso's. It will overwrite the file if the option is checked or create the same file with an alpha designator ie 100 and 100A.
You can add annitations and notes to the model on the Iso ribbon tab with Isogen Messages and Isogen Info functions. These will then be transfered to the isometric drawing
Mike G
Michael Gulnac
Technical Specialist
Organization
Autodesk, Inc.
”Boost
