AutoCAD Plant 3D General DIscussion
Valued Contributor
Rcfuss
Message 1 of 2 (138 Views)
Resistoflex Flange Navisworks Issue
138 Views, 1 Replies
07-03-2012 06:19 AM
Has anyone had problems when viewing Lined Piping in Navisworks?  When I view the piping in navisworks the pipe segment flanges are white not the color line layer or service it is on.
If I explode the pipe and match the properties of the line to the flanges that are white it works fine.
Valued Contributor
andy.davis
Message 2 of 2 (116 Views)
Re: Resistoflex Flange Navisworks Issue
07-06-2012 09:02 AM in reply to: Rcfuss
You're quite right.  I suspect it's the way that the flanges are added to the pipe and incorporated into the composite Plant item.  If you notice, when you select one of the flanges in Navis, the other is selected too.  The AutoCAD colour index  is always 7, white.
You can always Presenter to 'paint' the pipe. :-)
Andy
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
