AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
research spec
3 REPLIES 3
patpat78
856 Views, 3 Replies
research spec
hello i search a suitable spec that i can customise to works with this sort of fittings
any idea ?
thank's
3 REPLIES 3
Attila.Vallyon
in reply to: patpat78
It looks like a bell-spigot fitting.
There is no default catalog made for that yet.
But you can set up, there is BELL and SPIG end type already defined, and there is several similar endtype components in the catalogs.
Attila Vallyon
Hello Patrick,
Could Attila help you? As he said you can create this parts on your own in a catalog (Create new component...). Afterwards you can add those components to your spec.
Regards
Bernd G.
Senior Product Support Specialist
btrevena
These fittings are Tubepress stainless steel.
Cadgroup have a Tubepress spec as follows.
info@cadgroup.com.au
Spec: TubePress
Description: TubePress - SS 316L Tube with PressFit fittings
File Location: C:\AutoCAD Plant 3D 2014 Content\CPak Common\Cadgroup\TubePress.pspx
Last Saved: 5/31/2013 9:36:55 AM
-------------------------------------------------- BlindFlange --------------------------------------
15 to 100 FLANGE BLIND, FF, TABLE D, AS 2129
15 to 100 FLANGE BLIND, FF, TABLE E, AS 2129
-------------------------------------------------- BoltSet ------------------------------------------
15 to 100 Tubepress - Machine Bolt, AS 2129 Table D, FF
15 to 100 Tubepress - Machine Bolt, AS 2129 Table E, FF
-------------------------------------------------- Coupling -----------------------------------------
15 to 50 Tubepress - Barrel Union Female BSP, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring-Copy
15 to 100 Tubepress - F&F Coupling, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
15 to 50 Tubepress - F&F Union, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
15 to 50 Tubepress - Female Adaptor, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
15 to 100 Tubepress - Flange, AS 2129 Table D, FF, 1.4404 316L Stainless Steel
15 to 100 Tubepress - Flange, AS 2129 Table E, FF, 1.4404 316L Stainless Steel
15 to 50 Tubepress - Male Adaptor, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
15 to 100 Tubepress - Tube Adaptor, PN40, Bright Annealed 1.4404, 316L Stainless Steel
-------------------------------------------------- Crossover ----------------------------------------
15 to 25 Tubepress - F&F CrossOver, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
-------------------------------------------------- Elbow --------------------------------------------
15 to 100 Tubepress - 15° Pulled Bend, PN40, 1.4404 316L Stainless Steel
15 to 100 Tubepress - 30° Pulled Bend, PN40, 1.4404 316L Stainless Steel
15 to 100 Tubepress - 45° Pulled Bend, PN40, 1.4404 316L Stainless Steel
15 to 100 Tubepress - 60° Pulled Bend, PN40, 1.4404 316L Stainless Steel
15 to 100 Tubepress - 75° Pulled Bend, PN40, 1.4404 316L Stainless Steel
15 to 100 Tubepress - 90° Pulled Bend, PN40, 1.4404 316L Stainless Steel
15 to 100 Tubepress - F&F Elbow 45°, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
15 to 100 Tubepress - F&F Elbow 90°, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
15 to 32 Tubepress - F&F Thread Elbow 90°, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
15 to 50 Tubepress - F&M Elbow 45°, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
15 to 50 Tubepress - F&M Elbow 90°, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
15 to 50 Tubepress - F&M Thread Elbow 90°, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
-------------------------------------------------- Gasket -------------------------------------------
15 to 100 Tubepress - Gasket, AS 2129 Table D, FF, EPDM
15 to 100 Tubepress - Gasket, AS 2129 Table E, FF, EPDM
-------------------------------------------------- Gland --------------------------------------------
15 to 100 Tubepress - O-Ring, FKM Viton
-------------------------------------------------- Pipe ---------------------------------------------
15 to 100 Tubepress - Tube, PN40, Bright Annealed 1.4404, 316L Stainless Steel
-------------------------------------------------- Reducer ------------------------------------------
20 to 25 Tubepress - F&F Reducer Coupling, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
20 to 100 Tubepress - P&F Reducer, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
-------------------------------------------------- Tee ----------------------------------------------
20 to 100 Tubepress - F&F&F Reducing Tee, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
15 to 100 Tubepress - F&F&F Tee, PN40, 1.4404 316L Stainless Steel, FKM Viton O-Ring
-------------------------------------------------- Valve --------------------------------------------
15 to 100 Tubepress - 3 Piece Ball Valve, 316 Stainless Steel
15 to 100 Tubepress - BSP x Pressfit 3 Piece Ball Valve, 316 Stainless Steel, FKM Viton O-Ring
15 to 100 Tubepress - Pressfit 3 Piece Ball Valve, 316 Stainless Steel, FKM Viton O-Ring
15 to 100 Tubepress - Pressfit x BSP 3 Piece Ball Valve, 316 Stainless Steel, FKM Viton O-Ring
Bruce
”Boost
