AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Reporter
8 REPLIES 8
Message 1 of 9
evadmoore
685 Views, 8 Replies
Reporter
I need help with Reporter.
Why does my CS150 spec fittings merge with the Galvanized spec fitting?
I want them to print out as separate iteams so they can be purchased correctly.
8 REPLIES 8
Message 2 of 9
jabowabo
in reply to: evadmoore
You have to add the spec to the sort items at the bottom of your report setup. I would recommend adding every column property (except quantity) to the sort order items. This can screw you up big time if you don't catch it!
Message 3 of 9
evadmoore
in reply to: jabowabo
I will do that tomorrow. Sounds like this is what I need to do. Thanks
Message 4 of 9
evadmoore
You were very heplful with spec part of the Reports.
When I run a report it includes the Existing piping.
I has changed the Ststus of the Existing pipe in my model.
I only waht the BOM to show New piping.
Can you help me get that set up correctly?
Message 5 of 9
jabowabo
Open Report Creator, edit Report Configuration, then select Edit Query. In the bottom left area change the filter for 'Status' to <>'Existing'.  You'll have to do this for all Included Classes.
Message 6 of 9
celeste56
This explanation worked.  I found that every item in the query need the status change.  It isn't a one placement fix for all parts in the BOM, each part status change is required.
Message 7 of 9
oluwatosijn
in reply to: celeste56
i didnt see where i'm to change from status to existing.....please can you show me
OLUWATOSIN
Message 8 of 9
oluwatosijn
find attached for clarity purpose
OLUWATOSIN
Message 9 of 9
oluwatosijn
in reply to: oluwatosijn
please check is this one right? because i'm still facing thesame challenges
OLUWATOSIN
”Boost
