AutoCAD Plant 3D General DIscussion
Valued Contributor
patpat78
Message 1 of 7 (281 Views)
Report multiple sheet
281 Views, 6 Replies
07-26-2012 08:18 AM
hello
i try to use the report creator for generating a report with all instrumentation
easy :smileywink:
i made  sorting list by supplier but i need to generate one excel sheet  by supplier is it possible ?
thank's a lot
Sure it is. Report Creator can create almost every list.
Take a look at the video:
ftp://acplant.net/Videos/ADSK%20Forum/PR_Grouping_120727.wmv
Carsten
Active Contributor
cbeinecke
Message 2 of 7 (270 Views)
Re: Report multiple sheet
07-27-2012 01:14 AM in reply to: patpat78
Carsten
Valued Contributor
patpat78
Message 3 of 7 (266 Views)
07-27-2012 03:23 AM in reply to: cbeinecke
OK very nice thank you
but is it possible to put 1 supplier by sheet in excel ?
because in the preview it ok but in excel not
thx
Active Contributor
cbeinecke
Message 4 of 7 (264 Views)
07-27-2012 04:22 AM in reply to: patpat78
you can actually create various different file formats.
After you selected the report click on Edit... (I hope that is what the button says in the English version). Under "Target" you can define the file type and the path/filename.
For more details: go to http://docs.acplant.com/PlantTools/EN/PlantTools.html and look under: PlantReporter > Configuration > Create new configuration. Scroll down till hit find the topic "Output Type". Of course the whole chapter may be interesting.
Carsten
Valued Contributor
patpat78
Message 5 of 7 (262 Views)
07-27-2012 05:26 AM in reply to: patpat78
thank you very much it's work fine :smileywink:
Active Contributor
cbeinecke
Message 6 of 7 (258 Views)
07-27-2012 05:31 AM in reply to: patpat78
Tip: The layout of your report effects the layout of your Excel sheet. For example if you get very small columns in Excel it means that the objects in your layout are slightly either overlapping or they have a little gap between them. Just play a little with the position o the object to see the effect. If you understand how it works, you can start aligning all the object so the Exccel sheet looks nice.
Carsten
Valued Contributor
patpat78
Message 7 of 7 (248 Views)
07-28-2012 04:21 AM in reply to: patpat78
unfortunatly i was to quick to said it's work..
in pict 1 you can see it's ok in perview
but take a look of pict 2 the excel file....
what i need it's the same as preview but in multiple excel sheet any idea ?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
