AutoCAD Plant 3D Forum
Report Creator
7 REPLIES 7
Message 1 of 8
Eshleman78
2773 Views, 7 Replies
Report Creator
Is there a way to filter the 3dparts report to list items by the pipe spec?  Out of the box gives a total listing of all components.  It would be nice to break it down the materials by spec.
7 REPLIES 7
Message 2 of 8
jason.drew
in reply to: Eshleman78
If you edit the query and modify the sort order on the spec field, you can sort A-Z on the class names:
(see attached image for full-screen view)
Jason Drew
Designated Support Specialist
Message 3 of 8
Eshleman78
This did not get me what I was looking for, but it did get me to look closer at the report layout.  I added a cell called Spec as a heading and added a cell to pull the spec information from the database.  I attached an image.  This is getting me closer to what I'm looking for.  Thanks for the help.
Message 4 of 8
jason.drew
You're welcome. We're certainly glad to help.
I do have one other resouce which might be of use. There is a complete 255 page manual for the Report Designer located at this link below:
Report Designer Guide
It is also available in the local help folder of the installed path for Plant 3D 2012:
C:\AutoCAD Plant 3D 2012\AutoCAD Plant 3D 2012 - English\Help\report_designer.pdf
Thank you,
Jason Drew
Message 5 of 8
milic.srdjan
in reply to: jason.drew
Halo to You Smiley Happy
I see That You a Man for report things Smiley Happy
Please I post a problem on this link, because I do not wish to duplicate posts...
Look at Link to Problem
In short:
Is there a way, to use a filter that will use only components in report from Pipe Lines with specified caracters in Pipe Tag Name
Milic
Message 6 of 8
jason.drew
in reply to: milic.srdjan
Hi Milic,
The report query configuration allows for filtering in specific fields. You should be able to setup a wildcard filter using LIKE to look for a pattern:
Jason Drew
Message 7 of 8
milic.srdjan
Ok...
You are right about query: PIPE, because a pipe have TAG field, but if I wish to have...
e.g all ELBOW from same spec, e.g AAF3, and from pipe lines that have a part of name
2-DFG-2456-NEW12-AAF3
10-ADF-2456-NEW134-AAFZ
I will use
query:  ELBOW
filter
spec =AAFZ
and... what I will use for pipe tag, if I wish to extract ELBOWS only from NEW lines
and not from every line
Cheers
Milic
Message 8 of 8
milic.srdjan
Another question is
Why I can not put drawing numbers in line list if I take Query from P3DlineGroup
Is it close to P&D Drawing numbers, or to Plant3D drawing numbers...
For e.g. I wish to see "line number" "drawing number" (exact place where is that line design)
”Boost
