AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Report Creator - picturebox with variable pics
5 REPLIES 5
GSC_HAYA
767 Views, 5 Replies
Hello
in a report I've inserted a picture box. I want to change the URL (path) variable depending on the project with the content of a field in the project properties.
Is that possible or are there some other ideas?
Guido
Plant3D 2022 German
WIN10 Pro
5 REPLIES 5
Dan.Scales
in reply to: GSC_HAYA
Just to confirm the question, is it that you want a different image to be used in the report depending on the project that you run the report on?
Dan
Dan Scales
GSC_HAYA
in reply to: Dan.Scales
yes, this is exactly what I want.
Plant3D 2022 German
WIN10 Pro
Dan.Scales
Hi Guido,
I have logged a feature enhancement request with our developers for this functionality.
In the meantime you will need to use a different report for each project that contains the required image.
Dan
Dan Scales
PeterQuinn
The report creator has a very power scripting capability. You can do this with a some scripting. A good place to start is here: http://www.pdoteam.com/2012/06/introduction-to-scripts-with-the-plant-3d-report-creator/
Peter Quinn
Senior Product Manager
Autodesk, Inc.
GSC_HAYA
in reply to: PeterQuinn
here is the right answer.
I've contacted the support from DevExpress, they developed the reportcreator....
Assuming that the report data source collection includes a data field with the required picture URL value, use the Properties window -> Data Bindings -> Image URL option to link your picture box control to the corresponding data field (see http://screencast.com/t/prRMXWExxtM). It is possible to use this approach to link your picture box control to a report parameter (see the XtraReport.Parameters collection)
Many, many Thanks to the support.
Guido
Plant3D 2022 German
WIN10 Pro
”Boost
