I am trying to filter a custom DWG property in Report Creator. I can add a filter to any non-custom dwg property but it errors out when applying the filter to a custom DWG property. It says "The filter is not valid". It is not a syntax issue because the same string works on non-custom DWG properties.
Is this normal? Has anyone else seen this?
in my case, place single quotation marks for example,
Field: Insulation Thickness
Filter: >'0'
