Hello everyone.
I resently discover that i cant export from report creator to Xlsx files only to Xls.
Anyone know how to get the target file in the configurations to be to Xlsx insted of simple Excel File ?
I need to do this to get a new FootHeader on every page. A simple Excel file can take in taht data from the report creator.
I have change the export option for Xlsx files to Singel File Page by Page. This option i cant make on a Xls file.
Solved by Bernd.Gerstenberger. Go to Solution.
Hi Sap_joakim,
You can do this by switching into the tab 'Print Preview' and select 'Export to XLSX-File' (see attached snapshot).
Let me know if I could help you.
Bernd
Now four years later, there is still no real solution to this issue?!
Why can't one just select .xlsx in the main menu?
Because, when I change the file format as described, the automatic filename generation does not work, nor is the Folder preselected, etc....
Does anyone know if this has been resolved? Is the only way to export a report file to Xlsx is to select preview and then choose Xlsx manually?
