AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Report Creator error
3 REPLIES 3
Jorgen1990
602 Views, 3 Replies
Hello!
We have a problem with Report Creator 2014. We have a custom Report Template that works fine on the machine that is was created on. But it does not work on any other machines and gives an error:
Type: Autodesk.ProcessPower.ReportCreator.ReportCreatorException
Message: There are following errors in script(s):
line 186, column 53: error CS0234: The type or namespace name 'ReportTemplateTools' does not exist in the namespace 'Autodesk.ProcessPower.ReportCreator' (are you missing an assembly reference?)
line 196, column 50: error CS0234: The type or namespace name 'ReportTemplateTools' does not exist in the namespace 'Autodesk.ProcessPower.ReportCreator' (are you missing an assembly reference?)
Stack trace:
   at Autodesk.ProcessPower.ReportCreator.Manager.Preview()
   at Autodesk.ProcessPower.ReportCreator.MainForm.Preview()
Inner exception:
Type: System.Exception
Stack trace:
   at DevExpress.XtraReports.UI.XtraReport.AssertScriptsValidity()
   at DevExpress.XtraReports.UI.XtraReport.OnBeforePrint(PrintEventArgs e)
   at DevExpress.XtraReports.UI.XtraReport.CreateDocumentCore(Single progressRange, Boolean buildPagesInBackground)
   at Autodesk.ProcessPower.ReportCreator.ReportingFacade.Preview()
Any ideas what to do?
I attached the screenshot also.
Jörgen
3 REPLIES 3
jabowabo
in reply to: Jorgen1990
Can you post your report script text?  You can find it in report layout editor.
Jorgen1990
in reply to: jabowabo
hi!
I am unsure how to see the whole script of the report template. I can only see scripts of different parts of the report.
jabowabo
See the attached image in my post to locate the report scripts.
”Boost
