Hello!
We have a problem with Report Creator 2014. We have a custom Report Template that works fine on the machine that is was created on. But it does not work on any other machines and gives an error:
Type: Autodesk.ProcessPower.ReportCreator.ReportCreatorException
Message: There are following errors in script(s):
line 186, column 53: error CS0234: The type or namespace name 'ReportTemplateTools' does not exist in the namespace 'Autodesk.ProcessPower.ReportCreator' (are you missing an assembly reference?)
line 196, column 50: error CS0234: The type or namespace name 'ReportTemplateTools' does not exist in the namespace 'Autodesk.ProcessPower.ReportCreator' (are you missing an assembly reference?)
Stack trace:
at Autodesk.ProcessPower.ReportCreator.Manager.Preview()
at Autodesk.ProcessPower.ReportCreator.MainForm.Preview()
Inner exception:
Type: System.Exception
Stack trace:
at DevExpress.XtraReports.UI.XtraReport.AssertScriptsValidity()
at DevExpress.XtraReports.UI.XtraReport.OnBeforePrint(PrintEventArgs e)
at DevExpress.XtraReports.UI.XtraReport.CreateDocumentCore(Single progressRange, Boolean buildPagesInBackground)
at Autodesk.ProcessPower.ReportCreator.ReportingFacade.Preview()
Any ideas what to do?
I attached the screenshot also.
Jörgen
Can you post your report script text? You can find it in report layout editor.
hi!
I am unsure how to see the whole script of the report template. I can only see scripts of different parts of the report.
