Presently in report creator, the total bolt sets is getting displayed, what to make to show the quantity of bolts?
Somthing like this) Look at picture 1 and 2.
Welcome) I've seen that is possible!!! But I don't try it yet) I think you have to edit form in report, maybe make you own group, add parametrs: part size long description, bolt number in set, add sorting by bolt size, and make in the cell (bolt number in set) - total summ.
I generated it with expression field. It's not dificult.
You need to create the field wich is compare wich kind of object is it. In case of bolt it's necessary show field of bolts "Number in set", and other case you need to show Quantity field.
This is one example of expression:
Iif(IsNullOrEmpty([BoltSet_NumberInSet]) And IsNullOrEmpty([Pipe_Length]), 1, Iif(IsNullOrEmpty([BoltSet_NumberInSet]),Round([Pipe_Length]),[BoltSet_NumberInSet]))
First compare if the object is not bolt and not pipe, in this case the value is "1", and then if the object is pipe the value es pipe_length, and finally case if the all conditions are false (bolt case), the value es Numberinset.
