created line list report from P&ID's. everything works fine as long as i only chose 1 query (see report1.png/report2.png)
when i add a second query, for sorting purposes, things go haywire (see report3.png/report4.png)
what is happening here?
Solved by dave.wolfe. Go to Solution.
When you add another classes, similar records are not combined. You have to group records together in the report editor or find some other way (like acquisitions) to display the data you need for a class.
This post shows how to do it for nozzles. It should be the same idea for lines depending on which columns you want to show.
http://www.pdoteam.com/2012/03/nozzle-reports-for-autocad-plant-3d/
